Samsung HW-Q800A Soundbar Review & Comments
zubeir
For those who are not bothered about the auto calibration chromecast, the 2020 Q800T can be bought for £450.00
MahaRaja
Many Samsung bars are plagued with faults and loss of connection, wouldn't touch them with a barge pole myself.
lgans316
No more soundbars for me in home cinema room. Separates the way to go. It's okay as a short to medium term stop gap solution.
If these soundbars are made bigger with dedicated sub-outs then I will consider buying them.
They are not bad but lack of dynamic range, fidelity and most importantly bass becomes annoying on a long term.
Steve Withers
Reviewer
That's a great price for the Q800T, especially if you don't own a compatible Samsung TV and thus can't use the SoundFit auto setup. Samsung has also corrected the issues with multi-channel LPCM on its 2020 soundbars, so unless you want the option of expanding to 5.1.4-channels, you may as well buy the Q800T.
Clem_Dye
I’m not a fan of wireless subs., and I don’t see any mention of support fir older DTS codecs. A ‘maybe’ for me, at best.
Steve Withers
Reviewer
It supports older DTS codecs like DTS and DTS-HD, but these days it's usually DTS-HD MA, and by extension DTS:X.
zubeir
Buy any TV from Currys with the Q800T, add the promo code code to get £300 off. Cheapest TV is around £150, soundbar is £600 + TV, take off the discount code. making it a total of £450.
Ruffuz
There's also a (slim)chance of swa-9500s working with 2020 models, so should be able to get to 5.1.4
Clearandcolour
Can the new surround speakers for the backsound with upfiring speakers also be matched with the 2020 Q800T ??
Steve Withers
Reviewer
I don't know, but I guess it depends on whether the Q800T is capable of decoding 5.1.4, as opposed to 5.1.2 channels. I suspect not.
spsantos
@Steve Withers, Hi.
I´m Sérgio from Portugal and i´m thinking to buy a soundbar. Do you think that the new Q800A makes up for the difference of 300£ over the Q800t? The sound quality is muche better? At 450£ what soundbar you advise me?
Thanks.
sirbadger
Ticks all my boxes apart from the lack of HDMI ports 😬 would it be so hard to squeeze in a couple more? My GZ950 doesn't support eARC yet it's only a year old so I'm not going to be replacing it any time soon
Steve Withers
Reviewer
@Steve Withers, Hi.
Thanks.
While I haven't directly compared the two, as fas as I can tell they should sound identical because the differences this year aren't related to sound quality.
rb5201
This is tempting. For this q800t or the q70? Anyone have any thoughts on either?
zubeir
[What is the difference between Samsung HW-Q70T and HW-Q800T? £100 price
What TV did you use for this review? I can't seem to find it if mentioned, as all 2020 QLED's including my Q95T 55" can't send uncompressed LPCM 5.1 and 7.1 signals to my Q900T Soundbar unless it's connected directly to my soundbars HDMI port, which means I loose 4K 120 and a non-chroma subsampled image.
Steve Withers
Reviewer
It says in the review that I used a 77C9, and for testing I sent 5.1 and 7.1 LPCM directly to the HW-Q800A using the HDMI input.
Thanks Steve! Do you have a review on the QN90A or QN95A coming at all? Would love to know if the 2021 QLED's can actually send 5.1 and 7.1 LPCM to a soundbar vs the 2020 QLED's.
Steve Withers
Reviewer
No I don't, because Phil handles the majority of TV reviews.
bongo123
I bought the Q70 for £450 and managed to snag the rear surround speakers for £140, all in all I'm v pleased with the audio, big jump over my LGCX speakers but [email protected] Atmos speaker... Yeah I'm not hearing anything from those
ralphoi
I'm curious Bongo, how do you add rear surrounds? I thought only the q90r and 950 could have rear surrounds? Am I missing a really good trick here?
george1976
How on earth is £800 a mid range price? I would really like to know the explanation.
I guess £200 is small change these days..........
Podcast: LG C1 OLED + JBL Synthesis SDR-35 First Thoughts, plus TV Show & Disc Reviews & more
Latest News
What's new on UK streaming services for June 2021
  • By Andy Bassett
  • Published
Austrian Audio launches Hi-X65 headphones
  • By Andy Bassett
  • Published
Roku expands streaming content with Roku Originals
  • By Andy Bassett
  • Published
What's new on Netflix UK for June 2021
  • By Andy Bassett
  • Published
AVForums Podcast: 12th May 2021
  • By Phil Hinton
  • Published
