Samsung HW-N950 Soundbar Review & Comments
rb5201
Can anyone help?
I've hooked my xbox one x to the soundbar hdmi 1. Then sound bar to arc hdmi port.
I cant get picture on screen. If I change the output on the soundbar to hdmi 1 I get sound only.
TV Samsung q70 doesn't seem to recognise the xbox.
I can put xbox straight to tv and get sound and picture, but am I right in saying I won't get any atmos effects from the soundbar this way?
Smiler62
Try resetting the Xbox or unplugging the soundbar say for 10 mins then turning it back on .its worth a try . You will only get atmos from the tv if the set can output atmos like the LG C9 for example
chopples
It should pass through fine, I would check in the TV settings that hdmi signal plus is turned on for the ARC port, also freesync/ vrr will not work when the Xbox is connected to the bar, though I am not sure if it disables itself.
Tbh with only a dozen Atmos games and upmixing being disabled for none atmos games (this is due to the Xbox sending an Atmos signal with empty channels for none Atmos content) I would be inclined to just connect it to the TV
rb5201
Not seen the settings for the hdmi arc, will have another look.
Can love without the xbox games atmos, but if I use the xbox as a uhd player then I'll miss out.
Atmos through netflix from the tv should still work though shouldn't it?
chopples
If you are using it as a uhd spinner then yep I agree it better to connect via the soundbar. I have the n850, same spec bar, just lacking rears and the one x works fine with my 2017 Samsung q7.
Your Samsung is a 2019 model so Netflix Atmos should work over arc but u will have to enable the setting for Atmos and when you first watch Netflix change the audio settings on the TV to DD+.
Maybe try another cable from the arc port to the soundbar?
rb5201
Cables I'm using may be 1.4 not 2.0, would this be the issue?
Tried different cables but they are all a good few years old.
Romster1
Can anyone help?
[/QUOTE I havent got an xbox but plugging it directly into the tv and then connecting the bar to the tv's arc port should work. ensure that you turn on CEC on the tv and anynet+ on the soundbar. I couldn't get sound until I turned Sony sync on. on the tv and anynet+ on the soundbar. once I did that it was fine. also set your tv sound settings to passthrough so that all the audio streams are sent to the bar to decode
Smiler62
I dont think it really matters .the only position I could place mine is just in front of my tv stand with the cloth mesh side up against the wall and it sounds great 6D120C2E-9501-4110-9BEF-EBB61059B5CC.jpeg
jms_uk
So with those lucky 2019 Q90R soundbar owners finally getting the eARC update, and given the apparent hardware similarities with the 2018 N950, anyone holding their breath that we might get something also?
..I know, its Samsung so fat chance but given the whole "eARC update" thing actually started with it being a teased upgrade for the N950...
invisiblekid
HA!!
jms_uk
Yeah, my thoughts too... one can hope (but not too much!)
No chance, even though the firmware file will be near enough identical and the hardware clearly supports it they won't bother. Such a shame that such a fantastic soundbar can't be updated only 2 years after release.
Even Sony have released eARC updates for their 2018 soundbars...
invisiblekid
The lack of support/upgrades means this will be my last ever Samsung purchase.
1000% agree. Sadly, they make the best Atmos Soundbar ATM.
carlosv1
I love my HW 950, i think the surround is exceptional and not just for a soundbar. The only downer is I can't use ATMOS with my Xbox One X as I prefer the console being plugged into the TV directly
jms_uk
The odd sub & rear speaker disconnect aside, it sounds great! Just wish Samsung would up their game in terms of support and updates. Shame to see a mostly great bit of tech marred by a few issues and a manufacturer building more and more of a negative reputation for not giving much of a shizzle once they have your cash...
lukather101
Yeh still happy with mine apart from the occasional disconnect, no plans to replace anytime soon.
oscarmadfish
the sub seems the only thing that might have improved on the new one , think it does earc as well ?
jms_uk
Yeah, it got the firmware update this week. Can't see any reason why the very similar n950 shouldn't, except its Samsung 😒
Podcast: LCD TVs for Movies, Laser Projectors, RIP Ennio Morricone, AV & Movie news, B+W Matt Damon
Trending threads
Latest News
QDC Blue Dragon earphones on sale in UK
  • By Andy Bassett
  • Published
TV licence fee now applies to over 75s from 1st Aug
  • By Andy Bassett
  • Published
New H.266 video codec promises 50 percent data saving
  • By Andy Bassett
  • Published
Toshiba launches UL20 4K HDR TVs from £299
  • By Andy Bassett
  • Published
LG GX soundbar launches in UK
  • By Andy Bassett
  • Published
