Samsung HW-K950 Connectivity issues
Discussion in 'Soundbars, Soundplates & Soundbases' started by victor64, Apr 19, 2018.
  1. victor64
    victor64
    Aug 23, 2014
    11
    Hi all. Have lost connectivity to the Woofer and Atmos speakers somehow. I've read prev posts and have followed all auto and manual options. I've also tried updating the firmware via USB but nothing happened...Is there any way of identifying what version of firmware I have? And is there any way of getting this latest firmware (SAT-HAK16WWC) loaded via the internet to the Soundbar instead of USB? I see this vers. firmware deals with connection issues so would like this loaded. IE What do I actually do to get it loaded? There's nothing specific on Samsung sites unfortunately and I'm not much cop with the technical stuff... Thanks
  2. victor64
    victor64
    Aug 23, 2014
    11
    I've now downloaded samsung multiroom app and updated soundbar with firmware, but still no connectivity...out of warranty now, so am out of luck it seems, bother..
  3. yan101
    yan101
    Oct 28, 2013
    61
    +5
    How long have you had the kit? Ive returned a tv in the past after a firmware update rendered it useless, this was almost 4 years after purchase and went back to the manufacturer for replacement.... with a newer model as, lets face it, 4 years later that model was defunct. Not saying that should be your first port of call but worth considering. Electronics are meant to last 6 years according to trading standards
  4. victor64
    victor64
    Aug 23, 2014
    11
    I've only had it nine months, but it was officially sold as a refurb, because the brackets for the Atmos speakers were missing, unit itself was brand new..both Samsung and vendor are saying 'too bad'..
  5. yan101
    yan101
    Oct 28, 2013
    61
    +5
    Even so, you still have statutory rights for it to be working. They cant just say too bad because it was a refurb.
  6. synecdoche
    synecdoche
    Jan 17, 2014
    7
    3
    Have you tried a re-init? Switch on, hold down the settings button (the one with a gear on it) on the remote for what feels like forever. It'll show some info on the display and restart.
