So, I called Samsung support yesterday and they said the only way that both the tv and the sound bar would turn off and turn on at the same time is by using OPTICAL CABLE. They ran me through all the steps and it would somewhat work but not fully. It would turn off the tv, not the sound bar which was okay because there was no audio coming from the sound bar when the tv was turned off, so it's no big deal that the sound bar doesn't fully turn off but this way, I wasn't able to use the cable company's remote, i was forced to use the sound bar remote, I guess I can come over that by using the harmony one when i get it tomorrow(USPS failed as usual and did not deliver it yesterday).
Another annoying thing about this optical cable route is, I have to turn off the AnyNet+ off on both the tv and the soundbar.
This whole soundbar and tv working together thing seems to be a bit messy.
Steve, is there any other REAL WIRELESS SOUND SYSTEMS out there?
Where you can put your soundbar or speakers anywhere you want in your living room without any wires attached to them?
