Samsung HW-E350 soundbar help!
aboore
Hi, I am trying to connect my new Samsung HW-E350 sound bar to my new Samsung UE40EH5000 TV. I originally set up my sound bar by using a HDMI from cable box to soundbar and then another one from Soundbar to TV which worked fine! I then realised I couldn't use my PS3 without changing leads over etc so decided to plug both my cable box and PS3 into my HDMI ports on my TV but now cannot get the AUX input to work on the soundbar. I've connectors the red and white audio cable to the TV and plugged the 3.5mm stereo jack into the soundbar but still only receive sound from my TV, nothing from the soundbar! Any help would be excellent!
Thank you!
smileysmile
I have pretty much same problem with my samsung HW-E450 sound bar. I can't get sound from sound bar from dvd player. I have connected the sky box to sound bar and sound bar to tv. Dvd player is connected to HDMI (2) OF tv. Have you solved your problem?
Podcast: Best Hi-Fi products of 2020, Plus Best of the Month for TV Shows & Movies
