Samsung HW-C560S active subwoofer query
Discussion in 'AV Receivers & Amplifiers' started by williamh11, Nov 28, 2010.
  1. williamh11
    williamh11
    Jan 7, 2008
    13
    The package comes with a passive subwoofer but the instructions suggest that there's an active subwoofer out there that can be plugged in to the system as it has its own specific socket on the back of the receiver. Does anyone have any details about the active subwoofer - price and from where it can be purchased? Thanks.
  2. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,439
    If the connection on the back is a standard RCA phono then you should be able to connect any active sub to it without an issue. These start from around £100 upwards for a reasonable one.
  3. gchristofi
    gchristofi
    Nov 29, 2010
    30
