HI all,
Really appreciate any comments on this problem as it's driving me crazy!
Fed up with the Wifi continuously disconnecting from the soundbar and loosing sound so trying to hard wire through TV ARC HDMI option.
So I have a Samsung sound bar and Samsung TV both with ARC HDMI connections. Go into settings on TV and there is no option for ARC in the sound settings option -only the sound bar wifi. The manual says select DIN for the sound bar, but still no good.
I've just spent almost £50 on a super dooper cable as I read somewhere need one. It's directional and I've ensured is the correct way around.
I've also enabled the CEC function on the TV. I'm now officially Stuck.
Any suggestions would be great fully received.
I've lost the soundbar remote, but doubt if this is the problem as I can control the entire bar from the buttons on top.
Please please help me....
Many thanks
Chris.
Many thanks
Chris.
