Samsung HTX30R - DVD Region Hack?
Craig02
Hey guys i just joined :thumbsup:
Anyway i have been looking for awhile for this but cant find anything, I have bought myself a new home cinema system and it is a Samsung HTX30R now basicaly what i wanted to ask is there a remote hack to make this dvd player region free?
Craig
Oh shoot i have out this in the wrong place right?
It should have been in the DVD Player Hacks sub section :(
jlea3112
Found this info in the HT_TX35/ HT-X30 forum.
Havn't tried it myself yet and it is done at your own risk,
1. Remove Disc from Tray.
2. Switch Off Player
3. Wait 30 Seconds, Then Reconnect Mains.
4. Turn On player with Remote Control. Wait for player to Finish
Loading and Display 'No Disc'.
5. Press Enter on Remote Control. (There will be No On-Screen
Response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be No On-screen
Response.)
7. Press Enter on the Remote Control. Player will Automatically Turn
Off. 8. Turn Player On.
9. Open Tray
10. Close tray.
11. Turn Player Off then On Again.
12. Player is Now Region Free
Good luck.
V
valesavex
Hi Guys, i'm a newbie...i tried, but without success :mad:---
I followed instructions, but my system didn't turn off after the sequence...so i tried pushing the command 'repeat' after the 'no disc' info...then 'enter' anch numeric sequence...my sistem turned off...the i powered on, tray open & close, turned off and on, but always the same...proibithed disc!!!!!
Any idea?
Thanks in advance
Valerio
V
valesavex
probably the reason is that my player is HT X30 without "R"?....
ggr2k5
I have an HT-X30 and tried this multiregion hack, and my player is now locked to Region 1!
Region 2 disks give a wrong region error message.
Does anyone know if its possible to undo this hack?
Please help. 80% of my disks are Region 2
V
valesavex
For me this player remains a mistery!
Two weeks ago a tried newly and big surprise...it worked! So i was happy, and tried with other titles, but after two or three DVD, it stopped workin'...
I thought that was for that particular DVD, re-tried with the first working DVD and was locked!
So my idea is that now is region-free, but it has something other that locks my DVD-plyer.....
Pirate!!
Response.)
Response.)
9. Open Tray
10. Close tray.
Good luck.
Ahoy!
Please confirm that this works OK with the HTX30R. Also, what is the difference in spec between the HTX30 and HTX30R?
There's a firmware update for the HTX30R on the Samsung website (I know not what it does), but it's there. I wonder if the region hack will work after the firmware update?
Anyway, I'm in the market for an upscaler HTIB, but it needs to be region-free. Any help appreciated. A review would be nice if anyone knows where I can read one.
mooperman
dont know if you solved this cos your post is old now, but exactly the same thing happened to mine, have a look at my post in the owners thread to this system cos there is a way to reset it (and then re-do the hack).
sootyscott
Sorry - new to this site (probably put this in the wrong thread) Having same prob with my HTX30 - tried being clever & changed the setting now can only play USA DVD's - in "Speak for Dummies" how can I change it back. Thanks in advance
Colin
mooperman
Colin
have replied to your PM matey, also there is a 106 page thread here for this system
<click me>
it has loadsa helpful stuff in there... :smashin:
P
Paigey-Lou
Hey. I've tried this many times with my player. Each time failed, I've followed the instructions carefully each time, and after each failure reset the player. I don't know whether it is a different problem with my machine - it will only play 'copied' DVDs - or whether I am doing something wrong.
Hope you can help.
Paige. :)
mike79
Anyone got a link to this post on how to reset a Samsung HT? This is what I need for my 250X as it has gone from multi region to only region 1...
Sergio555
did you ever sort this problem as im exactly same position can not even play any movies I rent from blockbuster etc. please help (Nottingham UK)
Galacid
Response.)
Response.)
9. Open Tray
10. Close tray.
Good luck.
Hi guys first Post so please be gentle...
I see the above list of commands are to make the Samsung HT-X30 region free but from what I have read there may be issues with the system sticking on unwanted regions. Could someone tell me how to undo this hack before I attempt it...
LG G1 OLED Evo TV and SVS SB-1000 Pro subwoofer reviews, Samsung OLED rumours and more...
