Samsung HTDS400
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by nohoper, Jan 22, 2005.
  1. nohoper
    nohoper
    Hey Everyone,
    Wanting to purchase the above. Can anyone tell me the Handset Hack or if it is already Multi Region?
    Thanks in advance :thumbsup:
  2. gipo
    gipo
    Dec 22, 2003
    70
    11
    Sligo
    Like other HT models:
    1) Power ON using Romote (no need to switch off from the back and unplug it etc...) but make sure no disc is inside.
    2) Press 'Enter' on the Remote.
    3) Then press '8, 4, 2, 6, 9'.
    4) Press 'Enter' again.
    5) The dvd player should switch off to standby and say Good-Bye, if that happens then the code is R0 now.
    :clap:
  3. nohoper
    nohoper
    Gipo,
    Your a star. Thanks mate, I will try when I receive it. Already placed the Order.
