Samsung HTDM 150..which brand of discs?
B
bigbaddod
I'm finally going to take the plunge and buy a DVD burner to back up my movies etc. Would anyone have any advice as to any particular brand of blank disc they would recommend for the Samsung? or ones to avoid?
Thanks in advance,
George
bonzobanana
I've used various dvd-rs on my samsung and it plays without problems almost all of them. However I've done a few dvds on real cheap dvd-rs and these hardly read on anything but the samsung makes a good stab at them but normally starts pausing near the end. My recommendation is a good ritek based dvd-r and www.svp.co.uk should be able to sort you out. Basically though the Samsung HTDM150 isn't too fussy so as long as you buy reasonable quality dvd-rs you'll be ok.
