Samsung HT-X30R advice please!
Discussion in 'Home Cinema Buying & Building' started by jont123, May 8, 2007.
  1. jont123
    jont123
  2. Sq1rr3ll
    Sq1rr3ll
    Jun 14, 2006
    120
    28
    +22
    Extended facts for this SAMSUNG HT X30R
    Amp Output 800 watts rms
    This is the maximum audio / power output of the system. A larger power output gives better sound quality at a greater volume
    Colour BLACK
    DTS YES
    A multichannel audio source for synchronised film sound operating (usually using 5 separate speakers)
    Digital inputs NO
    Allows the unit to receive digital signals (from a DAB or digital TV receiver, for example) without losing quality
    Digital outputs YES
    Allows the unit to send digital signals to another unit / system without losing the digital quality
    Dolby prologic II YES
    An enhanced version of Pro Logic. Adds improved decoding for two-channel, non-encoded soundtracks and music
    Num of Speakers Supp
    5 Speaker System
    Radio Tuner Included YES
    Allows the system to receive radio channels and play them through the TV without the need for a separate unit
    Remote Control YES
    Enables you to operate your equipment from a remote handset
    Subwoofer Included YES
    A speaker designed to reproduce very low bass frequencies, usually those below about 80 Hz
    TV Tuner Included NO
    Has a TV tuner built in to the system
    Tuner Included NO
    Allows you to manually tune your system to the required frequency
    Wavebands FM
    The choice of wavebands this system is able to receive if it has a built-in tuner
    A few details via Dixons - only information at the moment.
    Samsung are notoriously slow at updating their website with new/upcoming products.
  3. Sq1rr3ll
    Sq1rr3ll
    Jun 14, 2006
    120
    28
    +22
    Hello again jont123
    Only just realised - manual that comes with my HT-TX35R also covers HT-X30.
    It appears that the only difference (from what I can gather - it's only an assumption) is that the X30 has the satelite type speakers - not tall boy.
    Other than that, there doesn't seem to be any difference in specification.
    That being the case, see thread regarding HT-TX35R - should fill you in on the details.
  4. jont123
    jont123
    Many thanks for the responses, much appreciated.
    I ordered today (£140, Dabs), which seems like a steal. Will post my views, etc in due course.
  5. 682194
    682194
    May 1, 2006
    138
    Was this unit any good??
    I've brought one today to connect to the HD-70 projector via HDMI..Can anyone comment if this will be any good.
    regards Ajay
  6. Jess4
    Jess4
    Looking at getting this as well.
    Downloaded the instruction book from Samsungs website and it clearly shows the unit WILL except an "optical" input and does not have an "optical" output. My new LCS tv model LE37R87BDX has an "optical" out port. This I hope will allow me to connect to two together
  7. davidskan1
    davidskan1
    Hi, I Have Just Purchased The Ht-x30. Just Wondering If It Can Be Changed To Multi Region ?? Thanx
  8. Y.M.S
    Y.M.S
    Jul 1, 2007
    425
    London
    Hi Davidskan1,
    Seeing as this system is exactly the same as the HT-TX35R apart from the speakers, you can try this hack out yourself. I found this browsing through other threads. Follow the step by step instructions properly:
    1. Remove Disc from Tray.
    2. Switch Off Player
    3. Wait 30 Seconds, Then Reconnect Mains.
    4. Turn On player with Remote Control. Wait for player to Finish Loading and Display 'No Disc'.
    5. Press Enter on Remote Control. (There will be No On-Screen Response.)
    6. Press 8, 4, 2, 6, 9 on the remote. (There will be No On-screen Response.)
    7. Press Enter on the Remote Control. Player will Automatically Turn Off.
    8. Turn Player On.
    9. Open Tray
    10. Close tray.
    11. Turn Player Off then On Again.
    12. Player is Now Region Free
    Please tell us how you got on.
  9. palantir pete
    palantir pete
    Dec 31, 2005
    28
    I bought one in Currys Superstore yesterday and I'm watching the Diana concert with TV sound thro' the HT-X30R ( analogue only as I'm waiting for an optical lead to arrive) and the sound is very impressive:
    Once I get the volume over 20, the vocals really jump into life.
    Plays DVDs fine - Sound effects leap about in a most satisfactory manner.
    I use mine with a Samsung LE 26 R88 in the kitchen/diner; 'cause the missus keeps hogging the 37" Tosh in the lounge!
    Pete
  10. nitrous
    nitrous
    Guys i wanted to know if the actual dvd player is the same as the x35r model, ive seen the pics on both models and they looked abit different
    has the X30R model got USB compatibility? because ive checked the spec for this model on dixons, currys and pcworld and non of them state whether it has USB comp
    thanks in advance if you let me know
  11. pmcgsmurf
    pmcgsmurf
    Jan 18, 2007
    858
    Scotland
    +64
    Yes it has, it is the exact same as the X35R as far as I can see.
  12. JonnyAlpha
    JonnyAlpha
    Mar 15, 2007
    111
    I have been searching for a good all round budget Home Cinema System and I think I`ve settled for either this HT-X30R or the HT-TX35.
    I have read the excellent thread on the HT-TX35R and having looked around the specs on these models seem to be exactly the same, the only difference being that the HT-TX35 has tall boy speakers.
    Whilst I am not a fan of tall boy speakers these ones don`t look too bad (Better than some wonky LG ones I have seen.
    The only thing that has put me off the HT-X30 is the speakers, whilst they are heavy enough they just don`t look the part??
    Why cant they sell the X30R with the same quality speakers they are selling with the very stylish but oh to big HT-X250R.
    I suppose I could buy the HT-X30R and buy some other speakers if I had the cash.
    If the specs between the two systems are the same then the decision will be on the speakers. Anyone know of a high street store or retailer in London that is selling the HT-TX35, I know tje HT-X30 is in Currys Digital at £199.99 and I saw it several weeks ago in PC World for I think an incredible £149.99.
    I have a Toshiba 32 C3030D and need the optical input for a future HTPC.
    Any comparison between the two systems??
    Ta
  13. nav187
    nav187
    hi, someone please help me!!!!
    when i connect my surround to my plasma i get sound from it when playing a dvd but how do i
    get audio whilst watching tv through my virgin media box,how do i connect everything up so theres audio coming out of the surround speakers watching virgin media do i need an other cables and baring in mind that theres only a scart and no rca connections on the back of the virgin media box.SOMEONE HELP ME PLEASE.
  14. kentish_lad
    kentish_lad
    Sep 14, 2006
    1,627
    Kent
    +192
    What outputs has the V box and how is it connected to the TV?
  15. nav187
    nav187
    the v box has only 2 scart connections one tv an one vcr,it is connected to the tv from the tv connection with a scart, and the x30 is also connected to the tv with a scart ,the surround works when playing a dvd but when switched to watching the v-box there is only audio from the tv itself none from the surround
  16. kentish_lad
    kentish_lad
    Sep 14, 2006
    1,627
    Kent
    +192
    From the x30 to Plasma use a HMDI cable (not scart) this free up scart 2 on plasma
    V box scart to vcr
    V box scart to Plasma Scart 1
    Phono out on plasma (red white) to phono on x30, if plasma hasnt got phono out, use a scart to phono cable from scart 2 to x30
    So to listen to V box audio through x30 you just change the input source on the x30
  17. nav187
    nav187
    im clear on everything but when you say v box scart to vcr what do you mean,because im not running a vcr unit i ment there was a connection on the back of the v-box a scart connection which says vcr im not actually running that
  18. kentish_lad
    kentish_lad
    Sep 14, 2006
    1,627
    Kent
    +192
    oh, i thought you have a vcr, you dont need that connection then
  19. nav187
    nav187
    does the x30 work with ntl boxes do you have one ?
  20. kentish_lad
    kentish_lad
    Sep 14, 2006
    1,627
    Kent
    +192
    As long as it has audio out yes
    No, i have SkyHD box
  21. nav187
    nav187
    im really geting impatient with this have you got any sugestions?
  22. Hansch
    Hansch
    Thanks for the Hack.
    Worked perfect on my HT-TX35.
  23. kentish_lad
    kentish_lad
    Sep 14, 2006
    1,627
    Kent
    +192
    Just do has ive said, come out of the TV to x30 with phono leads, if your TV hasnt got phono out (red white) go from scart 2 with a scart to phono adapter lead
  24. nav187
    nav187
    ive done that the pictures there but theres no sound my tv does have phono out do you think i need an optical cable?
  25. DrinksInBars
    DrinksInBars
    Apr 11, 2006
    1,221
    63
    +203
    you can run a n optical cable from the tv to the x30r and this works pretty well, or runa scart fromt he v+ box to your x30r as a sound/ phono input if you dont have optical.
    i got this system with my telly - and have to say for the price its awesome, only quibble i have is the usb playback can be very slow to start as it catalogues the usb drive for playback.
  26. buzz118
    buzz118
    Hi, can anyone tell me if the HTX30, hdmi connection up scales to 1080i or 1080p, thanks.
  27. JD09
    JD09
    Jan 2, 2008
    13
    Can anyone tell me the best way to hook up, for 5.1 on all sources?
    Tosh XF355 LCD
    HT X30
    Xbox
    WII
    VBox
    I have Optical cables and Switch so happy to use that.
    John
  28. JD09
    JD09
    Jan 2, 2008
    13
    Sorry forgot to say its an Xbox 360 (as Im sure it makes a difference)
  29. slybri
    slybri
    Jan 7, 2005
    15
    Sunderland
    If any one is after a bargain go to dixons web site and put in offer code SAMX30 and it will knock £50 quid of their price (£199) Ive just ordered mine today, by the way its the HT-X30R.:thumbsup:
  30. JonnyF
    JonnyF
    Jan 5, 2008
    37
    +3
    Just tried it but its out of stock in my area! Bugger! Really want this thing now as well, but cant find it any cheaper than £200!:thumbsdow
