Samsung HT-TZ315 - Does it Have Dolby Digital?
JonnyWiz
Hey all,
Great forum here, helped me a lot in the past,
I am just getting back into surround sound as finally got my lounge sorted,
Im looking at buying a Samsung TZ315 setup (£200 from pixmania)
Samsung HT-TZ315 HOME CINEMA SYSTEM review cheap prices HT-TZ315 HOME CINEMA SYSTEM Samsung best buy discount online uk shop
But some specs for it say it does have and some say it doesn't support Dolby Digital, only DTS & Pro Logic II
Can anyone clarify this for me, When i first got a surround setup years ago Dolby Digital was a must have so don't understand why this setup may not have it, or is there a new Standard decoder now that I should be using, everything I see flash up on Xbox games says Dolby Digital
Want to run Sky HD, Xbox 360 & Media PC through it (have a 3 way optical in switchbox)
Also does anyone know the main differences between the TX215 & TZ315 as the specs for the 215 definatly say it does support Dolby Digital
Thanks in Advance
JonnyWiz
andy1249
The link below is from the Samsung site , it does not have Dolby Digital , which is ludicrous for any surround system these days , Its also very badly advertised , ( 1000W rms my foot !!! ) and I recommend strongly that you look at other stuff as this and any of its brothers look like real turkeys.
HT-TZ315 home theatre systems - home theatre SAMSUNG
Try Sony or Panasonic for some nice all in one systems that wont break the bank. And for the most part they dont lie about their products either.
JonnyWiz
thanks for the reply, its weird though as the 215 which im guessing is a lower spec does have Dolby Digital!
can you recommend any models for under £250? that do have Dolby Digital & Optical In,
Oh and forgot to mention they need to be tall speakers! dont want any stands etc
Thanks in advance
kentish_lad
It does support DD, dont take any notice of on-line specs
andy1249
They are the manufacturers own spec from their own website , what are you supposed to do ? Buy it , cross your fingers and hope for the best ?
kentish_lad
Well i wouldnt take notice of any specs from your link because its the aussy model, samsung UK dont even show this model on its site
andy1249
The model number is identical , just the site is au , and I dont believe Australians in particular have any aversion to DD.
RottenFox
well seeing as the display has a DD 5.1 indicator on it, and the manual descibes in the settings,and troubleshooting guide steps to get DD5.1 from discs that have it, i would say it supports it..:smashin:
kentish_lad
The the omission of DD in the specs on the Australian site is a obvious mistake, what im trying to say is that although model numbers are the same, the specs do vary somewhat across regions, dont assume a particular product feature will be available to the same model numbers throughout the world. One example would be the Panasonics, online specs for these show they support DIVX but the UK version does not.
T
tyke2
Agreed!
In that Aussie spec it also says:
General
Total Power 1,000W
Number of Channel 5.1
so what would 5.1 be if it's not DD 5.1?
nobby1963
I have the system and it has Dolby Digital.
Hope that clears things up.
nobby1963
Hi Niklas,
Where do i start ..... its a long story !
As you can see by my AVF signature I am now on my third Samsung home cinema system.
The previous two different models failed with a Samsung known `protect` fault that caused the systems to shut down. Despite many attempts and different dignosis that put the problem down to over heating / speaker wiring / fan fault and others neither system could be fixed.
I am now on a 500R system that has worked for the last year.
I know I may have just been unlucky but I am afraid I would be wary to reccomend Samsung for home cinema. I am very happy with my Samsung TV and other Samsung products though.
Good luck with your choice.
niklas_hanssen
Hi Niklas,
Hi Nobby,
Thanks a lot for that...
Actually I was intrerested in this model because the specs look quite good for what I need and also because I also have a Samsung LCD TV...it would have been great to connect them and use only one remote control...
Anyway, another brand and model I was looking at was a Sony DAV-DZ660. It's a bit more expensive than the Samsung and I am not sure whether it's better or not than the Samsung.
After reading your advice I think I'll go for the Sony :)
Anybody can give me an idea about this model - Sony DAV-DZ660?
Thanks again.
Paramount + UK launch: Halo, Star Trek and Beavis, and all the latest 4K + Movie/TV News
