Samsung HT-TP33
Discussion in 'Home Cinema Buying & Building' started by newbieuser, Jul 1, 2005.
  1. newbieuser
    newbieuser
    Does anyone know much about the Samsung HT-TP33 as i cant seem to find any reviews on this product. I want to know if its any good and what the sound is like on this system.
    Thanks in advance. :thumbsup:
  2. daz1976
    daz1976
    Jul 13, 2005
    138
    Norwich
    +21
    Got one yesterday and today it's going back. If you went ahead and got one and are happy with it then no worries. I came from a reasonably expensive seperates Denon/Mission package so may have too high expectations.
    All in all I found it very boxy sounding and a massive gap between the upper midrange and the lower frequencies. Also the fan on mine was so loud it was annoying. Dvd picture was good though but nothing else positive I'm afraid.
    Hope that helps
    Daz
