Samsung ht-q100 2.1 speaker system, Connect to laptop?
Discussion in 'Home Cinema Buying & Building' started by bullzeye, Apr 16, 2018.
  1. bullzeye
    bullzeye
    Jan 21, 2013
    84
    Hi guys, just wondering if someone with audio knowledge can help me out
    i picked up the samsung 2.1 speaker system today, but not sure how to connect it to my laptop, my laptop has hdmi and headphone jack, but im not sure how to connect it to the speakers system
    i have attached a picture of the speaker system ports, if anyone can point me in the right direction to what wire i will need, i will be very gratefull. thankyou
  2. next010
    next010
    May 29, 2005
    10,718
    163
    +2,092
    The Samsung has an optical audio input so those options are
    1) Purchase a HDMI audio extractor which takes the audio from the HDMI port and turns it into an optical or analogue audio output. You will need to set the HDMI output as the default audio output in Windows or manually set your media player to use that as the audio out.
    2) Purchase a USB sound card with optical SPDIF output.
    For the red/white rca phono inputs same deal,
    1) HDMI audio extractor but use analogue output
    2) Get USB sound card with analogue audio output
    3) Use headphones output with adapter 3.5mm to RCA phono
  3. Jamie
    Jamie
    Jun 27, 2007
    5,186
    2
    Harrogate
    +1,329
    Just to add, some laptops have a dual purpose headphone jack that functions as both an analogue audio out and also as a 3.5mm optical output. Not all laptops but some do.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,333
    The Borders
    +3,424
    Are you using the Laptop with just the Soundbar or the Soundbar + a TV?
    Joe
