Samsung HT-DS110 Home Cinema - Help
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by YaZiN, Jun 25, 2004.
  1. YaZiN
    YaZiN
    Dec 4, 2002
    47
    11
    Kent
    I can't find ANY information or region hacks for this anywhere.
    I can't even find this on Samsung's own website.
    My father purchased a Samsung 43" Rear Projection set from Curry's last week and this was part of the pack.
    HT-DS110 DVD & Surround Sound set.
    Help :lease:
  2. YaZiN
    YaZiN
    Dec 4, 2002
    47
    11
    Kent
    Nobody able to shed any light on this at all?
  3. YaZiN
    YaZiN
    Dec 4, 2002
    47
    11
    Kent
    I have managed to successfully region hack this player using the same method for the Samsung HT-DM150 system.
    One small difference is that the HT-DS110 doesn't eject the tray after you enter the code, instead it says "goodbye" and switches itself into Standby.
    Successfully tested with R1 and R4 disc's.
    Unit was originally R2.
  4. rich1984
    rich1984
    Aug 30, 2008
    i need the code as well if anyone can help me
