Samsung HMX-H200 50p or 60p
rlittlefellow
Hi recently bought a Samsung hmx-h200. now i was of the understanding the camera shot at 60fps but in resolution selection it only shows for 720/50p or 1080/50i can anyone help
grahamlthompson
In memoriam
Those are normal for a UK sourced camcorder. Were you reading a spec from a US site ?.
grahamlthompson
In memoriam
Ah i might have i was just under.the impression that 60fps is.good for slow motion so.is 60p for.ntsc and 50p pal?
HD is neither PAL nor NTSC but the frame rates are historically related. In ntsc countries the mains frequency is generally 60Hz. NTSC is nominally 30fps (29.97fps). In PAL countries the mains are 50Hz and PAL is 25fps.
HD camcorders for 1080 progressive content use double the normal frame rate.
US based 2 x29.97fps UK based 2 x 25 fps.
For burning to DVDs for PAL countries 720 x 576 25fps is a lot easier to divide the frame rate by half. Same for NTSC 720 x 480 29.97 fps.
