Samsung HDMI aspect ration switching
Discussion in 'Samsung TVs Forum' started by 3rdDegree, Apr 24, 2007.
  1. 3rdDegree
    3rdDegree
    Dec 13, 2005
    266
    Dublin
    +12
    I was considering getting SkyHD.
    I have a Samsung PS-42S5H. I normally watch everything which is 4:3 in zoom mode (to protect the TV from screen burn) and let it auto-switch to 16:9 for any such content. Of course, all this works now from a Sky+ box via SCART. I was wondering if anyone else has this TV and could confirm if auto-switching or any kind works via HDMI (from SkyHD).
    Many thanks
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,529
    Norwich
    +986
    HDMI won't switch, hdmi carries widescreen resolutions so doesn't think it needs to.
  3. 3rdDegree
    3rdDegree
    Dec 13, 2005
    266
    Dublin
    +12
    Indeed, you are correct.
    But my understanding was some people here have had success setting the resolution on the SkyHD box to "Automatic" (as opposed to 720p or 1080i) and this has worked. Or at least, it has shown black bars at either side of the 4:3 picture.
    I guess my main question is: Does this work on the Samsung. Seems that the above working is largely based on how the TV handles the HDMI signal when set to "Automatic" on the SkyHD box.
    A secondary question would be: If the above worked, will it ALWAYS switch to 4:3 with black bars at the side, or can it be switched to zoom (to protect the Plasma from screen burn).
    Many thanks for taking the time to respond.
  4. Black Adder
    Black Adder
    Jul 16, 2004
    749
    +67
    Apparently the work around for this prob is to use component input for non-HD & HDMI for HD programs. Have both cable systems from your HD box to the TV.
