Samsung HD950 pink screen?
Discussion in 'Blu-ray & DVD Players & Recorders' started by bee123, Sep 12, 2005.
  1. bee123
    bee123
    Jul 24, 2005
    24
    3
    Can anyone help, its not happening all the time but is really annoying,its connected via hdmi to my pv500.Region 0 DVD's stays pink and i cannot do anything about it.
  2. multiply
    multiply
    Sep 7, 2004
    312
    Surrey
    +9
    Is it just Region 0 DVDs?
    I have the 950 connected to the LE31R41 via HDMI and have had no problems at all. However, I don't believe I have any Region 0 DVDs (although I can't imagine the Region would have any effect on the colour output).
    Just a thought - have you done the multiregion mod? It may be worth doing if you haven't.
  3. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,021
    48
    +43
    I have a pv500 and have seen a similar problem, its fixed by powering down pv500 and powering back up again. Not sure its the 950 at fault.
  4. bee123
    bee123
    Jul 24, 2005
    24
    3
    :clap: Thanks mutiply that done the trick :thumbsup: It must be that the samsung has a problem with region 0 when in region 2 mode.
