Samsung Hd950 In Stock.
Discussion in 'Blu-ray & DVD Players & Recorders' started by bee123, Aug 5, 2005.
  1. bee123
    bee123
    Jul 24, 2005
    24
    3
    if anyone is interested richer sounds have got them in stock 129.95 also for extra 20 quid you get an extra 3 year garantee, and if you do not use it just hand your receipt in and they give you your 20 quid back. :smashin:
    got mine yesterday from the middlesbrough branch.
  2. Shakey_Jake33
    Shakey_Jake33
    How does this compare with the Momitsu V880DX? I was all set to get the Momitsu, but I'm still looking at other options.
    The main reason I'm considering this over the Momitsu is the HDMI, which is more convienient for me than than DVI, but I recall various problems with the region hack messing up upscaling via HDMI, upscaling being the entire point for me. If region free only works via Component, which is what I suspect, obviosuly I'd bet better off getting the Momitsu and using DVI,
  3. bee123
    bee123
    Jul 24, 2005
    24
    3
    not sure about that, have got all equipment bar my plasma which is coming on tues 9th aug, once set up will try it out and let you know.
  4. paulmcp2403
    paulmcp2403
    Mar 29, 2005
    1,270
    63
    +116
    there are absolutely no issues with the region hack and upscaling continues to work fine :O)
  5. Unlight
    Unlight
    Jan 6, 2003
    1,438
    38
    Belfast
    +9
    Can anyone pick me one up and I'll pay the postage costs for it to be sent over here to N.Ireland??? I cant find anywhere with this in stock, including the Richer Sounds over here!
  6. AndyJ
    AndyJ
    Jul 15, 2005
    7
    Unlight - I'm also a NI resident and had enquired about this model in Richer Sounds. The guy that I spoke to said that they could order one for me.
  7. Unlight
    Unlight
    Jan 6, 2003
    1,438
    38
    Belfast
    +9
    Hi Andy!
    I was speaking to them this morning, and they said that they were getting them in at the start of SEPTEMBER!!!
  8. BurningHorizons
    BurningHorizons
    Aug 5, 2005
    3
  9. bee123
    bee123
    Jul 24, 2005
    24
    3
    just rang richer sounds middlesbrough and they have sold out. why not try
    www.pixmania.co.uk they had them in stock last night for 116.00 inc vat.
  10. Unlight
    Unlight
    Jan 6, 2003
    1,438
    38
    Belfast
    +9
    Pixmania require you to fax through proof of ID to them, which I cant do :(
  11. bee123
    bee123
    Jul 24, 2005
    24
    3
    why not? most garages will let you fax these days, for a small fee of course.
    have you tried http://www.digiuk.com they have some
    Samsung
    DVD-HD950
    Samsung's NEW High Definition Hypervision Compatible with DVD/-R/-RW/+R/ SACD/ DVD-A playable formats and DVI and HDMI DVD Player Price: £110.63
    £129.99 including VAT @ 17.5%
