Hard to quantify in percentage the improvement, I can just say thats it is very noticable, even the family said WOW! thats clear, so I guess that says it all?
The manual isnt exactly "War & Peace" but it has the required info and it is clear.
There are some caveats with this machine I think, for example when sitting very close to the screen some digital artifacts (in solid dark tones some pixelation) can be seen that can not when played back on the Sony 725, although I feel it might be just because with the DVI input it is so clear that you can see them, but when using the Component input it sort of smudges them together, this isnt a problem though, as from normal viewing distance they are invisible, I am talking two feet away max when I say close!!!
in total I am delighted with the purchase and feel I am getting the best from the screen now.
Now can anyone direct me to the hack for this machine please?
best regards David
