Samsung HD935 with 434
Discussion in 'Blu-ray & DVD Players & Recorders' started by Arshad, Dec 2, 2003.
  1. Arshad
    Arshad
    If i use the Samsung HD935 dvd player with Pioneer 434 plasma, will there be any problems? i mean are there any limitations since the cable used will be DVI-HDMI and not straight HDMI cable?
    Is it a good idea to use this player with the 434 at all?
    868 can't afford right now.
    Suggestions Please?
  2. Dutch
    Dutch
    Dec 5, 2002
    2,591
    3
    North Yorkshire
    +278
    Hi Arshad,
    All you'll lose is the audio by using a DVI output rather than HDMI, but I'm sure you'll be routing that to a separate AV amp anyway.
    Steve
