Samsung HD860 + Home Cinema
H
hardhousehead
I currently have a 2 year old dvd home cinema system whith optical connections.
Now I dont want to bin this system as its only 2 years old but If I buy a Samsung HD860 witch has optical out then can I connect my new hdmi dvd player to the home cinema system and use it as a amp? Also is there any other way of connecting them together?
Druboo
hardhousehead said:
Shouldn't be any problem. You should also be able to connect via phono if you want to use the Samsung as a cd player.
HTH
lapino
I once had a Samsung HD dvd player (hdmi), not sure which model. Played fine but had problems with divx scaling. Is this fixed now?
