Samsung HD850 picture settings
Discussion in 'Blu-ray & DVD Players & Recorders' started by Hiran, Aug 5, 2005.
  1. Hiran
    Hiran
    I have recently purchased the Samsung HD850 dvd player and have it connected to my Panasonic TH42PV500 plasma panel using HMDI connections. I am playing dvds at 720p resolution and the picture quality is pretty amazing. However I wanted to ask what would be best setting for the HDMI digital data RGB range. I have the dvd output set at RGB Normal but have the option to change it to RGB-Expand, YCbCr (4:4:4) and YCbCr (4:2:2). Can anyone please help me or advice me with which setting I should go with for the best possible picture. Does ot make a difference? what do these settings mean? Many thanks in advance :thumbsup:
  2. nick501
    nick501
    May 6, 2005
    7,203
    Walsall, West Midlands
    +782
    someone told me to use rgb expand. I would also like to know how each one is different as I cant really tell any difference between them.
