Samsung HD850 Maximum Mpeg4 Res
dgsgc
Hi guys,
Hopefully someone can help me.
Is there a maximum resolution and bitrate at which the sammie can play mpeg4's, xvid or divx im not fussed. I know xvid can produce much higher resolutions, they just dont seem to play. If anyone knows the samsungs max res it would save me days and days of experimenting with autoGK.
unique
dgsgc said:
Hi guys,
i'm pretty sure its the same as dvd resolution, thus 720x480/576 depending on pal or ntsc. thats the same restrictions as most dvd/divx/xvid standalones. not sure about the bitrate, but the manual should tell you (you can download it)
dgsgc
Thanks, i checked the manual (pdf) and it doesnt make any mention of it anywhere. Ill check the paper manual when im home.
I pretty much expected it to be 720, thanks for conforming it for me.
