Samsung HD850 is its 720p 50 or 60Hz
Discussion in 'Blu-ray & DVD Players & Recorders' started by hendern88, Aug 19, 2005.
  1. hendern88
    hendern88
    Mar 6, 2005
    52
    I have a Samsung LW22A13W which will happily accept a 720p signal from my HTPC but only at 60Hz.
    I cannot get any signal when connecting my HD850 via HDMI-DVI lead as it say unsupported mode.
    I can only think that the HD850 outputs 720P at 50Hz hence it works fine on my Samsung LCD Rear projec but not the little one.
    Many ideas before the HD850 goes on ebay ?
    cheers
    Neil.
  2. hendern88
    hendern88
    Mar 6, 2005
    52
    all sorted....if I used NTSC output from the HD850 it all works fine.....dono why as when select PAL ....the picture goes off....anyway working fine now..
    cheers
    Neil.
