Samsung HD850 & BTB & DVE
Discussion in 'Blu-ray & DVD Players & Recorders' started by Ponty, Sep 22, 2005.
  1. Ponty
    Ponty
    Feb 15, 2005
    68
    Just got my DVE disk and stumbled at the first hurdle...
    I don't see the outer vertical black bars, and a quick bit of searching on the forums and it appears that its most likely the DVD not passing below black?
    I'm using via HDMI cable
    Any suggestions or workarounds/hacks etc?
  2. pknarb
    pknarb
    Aug 29, 2005
    47
    Try adjusting the HDMI settings (RGB normal, RGB Expand, YCbCr-(4:4:4), YCbCr-(4:2:2)) and then see if things improve.
    I have an HD950 myself and don't quite know what the correct setting is when connected to an LCD. Does anyone know?
  3. radiokid
    radiokid
    Oct 19, 2005
    121
    Leeds
    I have this player as well, what is the difference between the different options above? RGB, RGB Expand etc.
  4. bonc
    bonc
    If i'm correct, this player dosen't pass Blacker than Black!
    Hence why you cannot see the outside darkest Bar!!!
    correct me if im wrong guys!
