samsung hd745
Discussion in 'Blu-ray & DVD Players & Recorders' started by bigdavie0, May 4, 2005.
  1. bigdavie0
    bigdavie0
    i have a techwood twp4210 with dvi connection but it does not have component connection will i be able to connect sammy hd745 to techwood via dvi
    thanks in advance :confused:
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,134
    +564
    The 745 does have DVI if that's what you are asking...PJ
  3. bigdavie0
    bigdavie0
    thaks for the quick response pjtx100 i know the samsung has dvi but i read in a previous thread that you had to connect component as well as dvi but my tv does not have component connections
    cheers :thumbsup:
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,134
    +564
    Nope, you don't have to connect component.
    I've seen reports that you need to connect composite (ie single yellow connector) in order to get to the menu to configure it use the DVI connector. However in my case I didn't have to do this. I just plugged in the DVI lead and away I went....PJ
