Samsung HD 850 v's HD 745
Discussion in 'Blu-ray & DVD Players & Recorders' started by paulmc, May 10, 2005.
  1. paulmc
    paulmc
    Apr 24, 2005
    68
    Is the 850 better / worse does it have more or less features?
    I am looking for a DVD that uses the Faroudja chip set to improve the fast motion blurring 'fuzzing' on my Optima H30a
    The HD 850 is also cheaper than the 745 strange
    any thoughts
  2. Br41ns
    Br41ns
    Apr 5, 2005
    424
    Glasgow
    +31
    :hiya:
    Biggest difference is the 745 uses a DVI connection whereas the 850 uses HDMI. I have the 945 which uses HDMI also, PQ is excellent. The sammy players are generally very good and they have no probs with reg 1 discs. Only prob with the sammy is there are a couple of s/ware issues but once your watching a film you soon forget these. Id say either get a 945 or get an 850 or 950, they're all great value for money. :smashin:
  3. paulmc
    paulmc
    Apr 24, 2005
    68
    Oh I just bought one. I hope this will fit my Optoma H30a it has DVI input does the HDMI plug into the DVI.; I read that the 850 has a DVI out as well is this right :suicide:
  4. nigelbb
    nigelbb
    Apr 4, 2005
    5,307
    103
    +491
    I doubt it. My HD945 came complete with HDMI->HDMI cable plus HDMI->DVI cable. Check the specifications.
  5. MKPatrick
    MKPatrick
    Dec 11, 2003
    344
    Buckinghamshire
    +11
    I can't see any reference to the 850 being Divx/MPEG 4 capable or SACD/DVD-A capable. Given it's phenomenally low price point I'm guessing it oes none of these.
    This would be the primary set of differences between it and the 745 (which does all the above) along with the HDMI output on the 850 compared to DVI-d on the 745.
    Don't forget that HDMI video and DVI video are identical, HDMI simply adds digital sound capability to the connector. HDCP is carried on both HDMI and DVI signals.
    Patrick
  6. KoThreads
    KoThreads
    Jan 18, 2005
    3,016
    +182
    You are right.
    See the sammy 850 thread as the 950 (just ordered for £128 inc p+p) has the lot. The 850 has no DVI you need a £13 adaptor.
  7. stormjai
    stormjai
    Nov 15, 2003
    331
    Bromley
    +3
    Does 850 do DIVX/MPEG 4?
    not so interested in DVD-A or SACD
    Ta
  8. KoThreads
    KoThreads
    Jan 18, 2005
    3,016
    +182
    Doesn't look like it, but it is on the front of the 950
  9. gingerone
    gingerone
    Dec 10, 2002
    2,556
    +383
    Is the picture quality on the 850 and 950 the same?
  10. KableMan
    KableMan
    Feb 9, 2005
    610
    Solihull
    +88
    I hope so I just bought one - £95 including shipping :smashin:
    From everything I've read they are the same player barring the facia, and the DVI, SACD and DVD-Audio on the 950. I have a TV with HDMI and I'm not going to use it for playing music so these are not features I need and at this price its a fantastic bargain. This is basically the same player as the HD945 which HCC rated player of the year 2005 when its rrp was £200+!
    Also I checked the manual - you can see the UK version via the Australian website and it explicitly says the 850 supports DIVX.
    KableMan
    PS. Has anyone who ordered the player from softjam recieved one yet?
  11. gingerone
    gingerone
    Dec 10, 2002
    2,556
    +383
    Cheers Kableman, that's all I wanted to know, I'm going to order one as well now.
    I will never user dvd-audio or sacd so it's pointless paying extra and waiting for the 950.
  12. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    745 SACD sub out doesn't work anyway.
    However I wanted DVI.
    850 sounds a storming bargain though!...PJ
  13. MKPatrick
    MKPatrick
    Dec 11, 2003
    344
    Buckinghamshire
    +11
    i'm one oft te few people who deosn't have the sub out issue - on my 745 the sub works perfectly for both dvd-a and sacd (main speakers set to small)
    Patrick
  14. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    That is interesting. Must have been a dodgy batch, or perhaps you got one of the good batch? :) ...PJ
  15. justthekiddy
    justthekiddy
    what scaler do the 850 an 950 use? do they use faroudja dcdi ?
    The answer doesn't seem to leap off the page at me. I apologise now if someone has already said.
  16. MickyGee
    MickyGee
    Jan 6, 2005
    294
    Preston
    Zoran 7 chipset for the 745/945 for scaling, not Faroudja. Works pretty well without the macroblocking which afflicts the Faroudjas. If you search the 745 threads - lots of info.
    Not sure about 850 though !
  17. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    I've been watching National Treasure on the PJ the last few nights (fell asleep both times so you can tell how gripped I was). Unusually I've been using the 745 via DVI (the 575 via component is the main player) and I decided to revisit some of the PJ's settings, I switched the DVI input type on the PJ from DVD to COMPUTER and the PQ became a lot punchier, brigher, more shadow detail. I'm now even more impressed with the 745. Still not quite as sharp as the Pio but pretty close and I'm amazed at the lack of artifacts...PJ :)
  18. MickyGee
    MickyGee
    Jan 6, 2005
    294
    Preston
    I have my LCD also set 1:1 (i.e pc mode) and that gives a much better colour balanced image. Interesting.
  19. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    I have the sammi 850 and i am a little disaapointed.
    Yes-HDMI to HDMI, div-x , not SACD
    PQ attaches to Hitachi 42PD7200-OK only when comp with Tosh 330e via comp (I)- the tosh has more detail and more natural colour and more depth
    Is there something I am doing wrong?
    Please Help
    Azz :lease:
  20. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    I addition in HDMI mode cant change aspect ratio via TV only by DVD-The TV appears to do a better job of it ie pic still natural etc
    Yes i took the HD leap and i am a little disappointed
    AZzz
  21. MickyGee
    MickyGee
    Jan 6, 2005
    294
    Preston
    Out of interest try the Sammy upscaled in Component and see how it compares. I get a very good component PQ as well as DVI. To upscale in component you need to apply the MR hack.
  22. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    I tried to in component and the MR hack-the hack works but in HDMI when upscaling the screen actualy switches ie black then pic and for some reason misses out 768p. In component not switching just scrolling ie can see setting changes.but pic the same no delay.
    Someone let me know if this should happen please.
    Azz
  23. neil c
    neil c
    Mar 25, 2005
    537
    +3
    Where did you guys get the HD745 from? I'm interested in the Samsungs ability to upscale over component, as my PJ only has a component.
    I've seen the HD850 and HD950, but is the HD745 the only one that can upscale to HD over component (with the hack)?
  24. masher
    masher
    HD850 upscales via component after the hack
  25. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    Masher
    Are you sure? My 850 upscaling via hdmi- yes you can see something happening and there is a delay.
    Component no changes evident and no delay just the resolution indicator changes in the top LH corner even after the hack
    Azz
  26. masher
    masher
    Hi Azz,
    mine does. TV confirms the new resolution being input also. Are you sure you have done the hack correctly (I had to try a couple of times before it worked :confused: ).
  27. zoro
    zoro
    Jan 23, 2003
    325
    +7
    I could not do hack, but still resolution change numbers are evident via component, but picture does not change! But I prefer PQ via HDMI any ways!
    Looking for a region hack on US player desperately? Any one?
  28. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    Hi masher,
    I tried the hack once and inputed no 9 (region free) and it works with region 1 and 2 disks. My TV hitachi 42pd7200 after pressing info all it says is component or hdmi nothing about resolution.
    Any ideas
    Azz
  29. daveyjay
    daveyjay
    Nov 18, 2004
    59
    +10
    Zoro look on videohelp.com-you need an Aiwa remote or a Palm which you program with Aiwa codes,I successfully hacked a DVD-HD841 this way which I bought in the States
  30. zoro
    zoro
    Jan 23, 2003
    325
    +7
    Thanks dude!! got it! usd philips remote, programed to Aiwa..all done!I must say pal to ntsc is darn god! I am just waiting to see how much better is hd-950.
    For $116 this player is a stealer deal imho. short of doing divx, but i never checked though!
