Samsung galaxy s3 apps not automatically updating
Discussion in 'Mobile Phones Forum' started by paul777, Sep 1, 2013.
Tags:
  1. paul777
    paul777
    Dec 24, 2009
    290
    +8
    Samsung galaxy s3 apps not automatically updating. I have un installed Google play updates and download manager. I cleared the data there was no cache to clear, I don't know if that's the problem so I have un installed the updates for YouTube and it's been over an hour now and it still hasn't updated. Auto update is enabled in Google play store and when I go to my apps YouTube is there to be updated. Any advice please.
  2. BenTheBookie
    BenTheBookie
    Apr 6, 2006
    511
    28
    +56
    Try a phone reboot? Normally forces my apps to update that way
  3. paul777
    paul777
    Dec 24, 2009
    290
    +8
    I forced stopped it there just now and restarted and it updated. Going to try another one thanks mate.
  4. paul777
    paul777
    Dec 24, 2009
    290
    +8
    Looks like I have to restart all the time now, didn't have to do this before. Does a factory reset stop you from encryption it says it does but that doesn't make sense as you are putting it back to being straight out the box.
  5. shlips
    shlips
    Aug 30, 2013
    9
    +5
    I had the same problem as you and i removed the battery for a few minutes and seemed to fix the problem.....might not work for you but did for me....now my auto updating seems to work.
  6. paul777
    paul777
    Dec 24, 2009
    290
    +8
    Thanks I will give it a go. No it never worked for me does doing a factory reset disable encryption? It says it does but that doesn't make sense as you are putting it back to being straight out of the box.
  7. shlips
    shlips
    Aug 30, 2013
    9
    +5
    Not that im aware of....just erases everything on the phone....so do a back up first.
  8. shlips
    shlips
    Aug 30, 2013
    9
    +5
    Also some apps need to be updated manually.
  9. paul777
    paul777
    Dec 24, 2009
    290
    +8
    I will contact Google first before I do it and see what they say. I changed maps back to the older version and disabled updates, but I have now had the auto update for maps enabled for days now and it won't update to the newest version.
  10. shlips
    shlips
    Aug 30, 2013
    9
    +5
  11. paul777
    paul777
    Dec 24, 2009
    290
    +8
  12. shlips
    shlips
    Aug 30, 2013
    9
    +5
    I dont have the email but the phone itself is the easiest way to do it.....your phone will do backup and auto factory reset.
