jacksoninho
Hi. Ive just purchased a 43 inch Samsung Frame 2021 TV and have had it professionally mounted as part of the deal with John Lewis. I'm now looking to chase a channel into the wall to hide the 'invisible' one connect cable and I had a couple of questions.
I only need a 60cm run to hide the cable behind a solid block wall. I was planning on doing this old school with a hammer and chisel, and maybe an angle grinder if needed.
Can anyone please recommend behind the wall trunking that would be good for a single cable? Everything I've seen on Amazon is for on the wall trunking.
The One Connect cable itself, from what I'm reading isn't actually fully certified for behind the wall implementation. The way is see it is that it is a very short run, but is this too risky?
Can anyone please recommend any decent filler that I should use for when the trunking has been mounted?
I've attached a photo of the TV and the location.
