Samsung F6800 TV with Freesat. Cannot use RF from sky and then switch to inbuil
Discussion in 'Sky Digital TV Forum' started by ADAMFOULKES, Aug 10, 2013.
Thread Status:
Not open for further replies.
  1. ADAMFOULKES
    ADAMFOULKES
    Mar 20, 2009
    310
    Droitwich, Worcestershire
    +29
    Hello there,
    I have recently bought the new 2013 Samsung f6800 LED tv for the kitchen diner. I have had it professionally fitted and I have had an rf link added so that I an watch Sky TV on it too.
    I recently came against a problem in that if I wanted to watch the inbuilt freesat TV, the RF channel for sky then became unavailable.
    The installer said that Samsung had changed the menu options and it didn't seem obvious to know how to switch between the two. I wonder if anyone else has the same TV and has figured a way round this?
    It's a bit annoying as I specifically wanted to view freesat hd for some programmes but I don't want to have to go though the rigmarole of retuning the rf channel every time to watch sky!
    Thanks in advance.
    Adam
  2. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,435
    Redditch
    +4,158
    How do you know it's not available ?
    If you are using the satellite tuner then you will have to switch the set back to use the terrestrial tuner (in this case in analogue mode) to tune into the analogue PAL TV channel the modulator is creating.
    The TV doesn't appear in a quick search to have a satellite tuner at all.
  3. logiciel
    logiciel
    Feb 2, 2008
    53,104
    UK
    +5,759
  4. iaint
    iaint
    Jul 4, 2011
    640
    28
    +89
    Hi.
    The e-manual is pretty useless, but seems to suggest menu -> broadcasting -> channel list and press right arrow. or menu -> broadcasting -> aerial.
    Do either of these make any sense?
    Regards, Iain.
  5. ADAMFOULKES
    ADAMFOULKES
    Mar 20, 2009
    310
    +29
    Hello all,
    Thanks for taking the time to help. Ian's suggestion worked a treat.
    Thanks again !
Thread Status:
