samsung F6800 backlight fault ?
Discussion in 'Samsung TVs Forum' started by goatie, Aug 29, 2013.
Tags:
  1. goatie
    goatie
    Jun 2, 2013
    7
    hi folks
    had a Samsung F6800 for a few months now
    over last few weeks it looks like the light/brightness of the picture is switching off
    its easier noticed when i'm watching a football match, it looks normal then suddenly the picture goes dark, just like they have switched off half the floodlights at the ground
    last night when it happened I tried other satellite channels and tv builtin tuner to prove its TV or satellite box, the dark picture was on both satellite and TV tuner
    is this a know fault with Samsung TV's is there a name for this fault
    I'm going to get on to JL today to see what they saybut any advise would be a help
    thanks
  2. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    Thread moved
    Curly
  3. Samorlg
    Samorlg
    Apr 16, 2008
    2,485
    +116
    Just curious, have you timed it, is it the exact same amount of time every time from switch on or can it be after 5 minutes, or on another occasion take two hours say? if yes to the former maybe it's a screen save function, does your Tv have such a thing???, but if the latter then it's likely a hardware fault I would think, hope you sort it.
    Just to add, I did read in the on-line manual that your TV has an Eco mode, this will automatically adjust the back light to help prevent over heating, is it in this mode?
  4. goatie
    goatie
    Jun 2, 2013
    7
    thanks will look to check if eco mode is there
    normally notice it when watching football matches,
    think it happens after tv been on for a few hours, not checked if its a certain time each night or for length of time tv been on for,
    think its ramdom when it goes back to normal. but again not checked that
  5. goatie
    goatie
    Jun 2, 2013
    7
    had a look
    the eco mode is off
  6. Samorlg
    Samorlg
    Apr 16, 2008
    2,485
    +116
    A possible solution is to update the firmware, could just be a glitch.
    I would also turn everything off that controls the back light and any Auto contrast controls, so we know Eco mode is off, there's also an Auto dimming feature that's dependent on ambient light, make sure that is off too, if there's anything else that may alter it, turn them off too, so power consumption controls etc. If after all of the above have been changed and it's still apparent to you, call JL and have them look at it, quite possibly a hardware fault.
  7. goatie
    goatie
    Jun 2, 2013
    7
    thanks i'll try all that in next few days
    the trouble is now I've got it in my mind i'm not watching the progamme i'm looking at the picture and any little change in lighting has me thinking its failed again
  8. Samorlg
    Samorlg
    Apr 16, 2008
    2,485
    +116
    Something Samsung Tvs do is to auto-dim or brighten anyway, no amount of altering the above controls will make this go away, it's used for the purposes of overall contrast, you may notice the screen dim slightly with darker scenes and the reverse with brighter scenes, a lot was said about this feature about five years ago and it seems it's still being used, it can be tamed a little by using the "standard" picture mode or equivalent, if you use "dynamic" mode it will be more pronounced, just something else that may help you.
  9. goatie
    goatie
    Jun 2, 2013
    7
    thanks, I've got tv in standard mode
    going to have to look at controls and update to firmware
    only started to notice it in the last few weeks,
    notice it at night, now as nights are getting dark earlier I have room lights on, wonder if its something there to do with it
  10. goatie
    goatie
    Jun 2, 2013
    7
    thanks for your help
    checked last night and in the TV's menu I had turned off the eco in 1 sub menu folder
    but found another eco setting in a different sub menu
    turned eco setting off TV backlight on now
    thanks again
  11. Samorlg
    Samorlg
    Apr 16, 2008
    2,485
    +116
    No problem, you can now enjoy that suburb Tv of yours, glad I could be of help.
