Samsung EIS Colour View Finder 24x
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by gazberotten, Aug 15, 2004.
  1. gazberotten
    gazberotten
    Hi i am new to the Av forums scence and have come here for help. I own a Samsung EIS Colour View Finder 24x and i have some problems.
    When i switch on the camcorder a message comes up on the screen d.emg every time i switch it on i can playback my tapes but not record. What is the problem i am expeiriencing.
    Hopefully someone could show me how to counter act this problem as it has been upseting me for sometime now
    Any help is apreciated
    With thanks
    (gazberotten)
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,259
    Rainham Essex
    +2,403
    Hi gazberotten and welcome to the forum!
    My guess would be that you need to clean the heads on your camcorder. Get a DV cleaning cassette and use that and this will hopefully clear the error message.
    If this does clear the problem then I would suggest that any old tapes you have been useing get replaced. If the tapes are old they will likely have dirt on the surface that gets transfered to the heads of your cam. New tapes are now around £3 each online so not too expensive. Also you must keep to a single make and type of tape as the heads can get clogged up by different coatings on the different makes & types of tape.
    Mark.
