Samsung e700 WAP over GPRS
Discussion in 'Mobile Phones Forum' started by MattChadd, Nov 11, 2003.
Tags:
  1. MattChadd
    MattChadd
    Hi all,
    Just gone and upgraded my phone from a t68i to a e700, and what a great phone it is!
    Having loads of getting the phones settings to my liking, but have come across a problem. I want to disable the GPRS WAP settings on my phone and enable the standard WAP. The reason being the my service provider, T-Mobile, charge something like £7.50 per MB of data trancieved!
    Can anybody tell me how to do this PLEASE??
    Thanks in advance
    Matt
  2. nokiaman
    nokiaman
    Hi mate, it's a shame your not on orange as i get 1MB a month free all year :)
    Ok to reset your phone try these settings.
    (I've give you all the settings you only need some of them for a samsung so just see which ones it is and your away using normal dial up wap)
    Profile Name: dial up wap( or what ever name you choose)
    Homepage: http://wap.t-mobile.co.uk
    conection type (dont think you need to choose this on a samsung)
    continous
    Sercurity: off
    Bearer: data
    Dial up number: +447953 968 999
    IP Address: 149.254.001.010
    data call type: ISDN
    Data call speed: 9600
    User name(Login Name): User
    Password: wap
    Port 9201(dont need this on a samsung either)
    Let me know if you need help as i will tell you what you need.
  3. MattChadd
    MattChadd
    Thanx nokia man,
    Those settings work perfectly. I cant believe T-Mobile charge £7.50 per MB of data, thats why i am changing my settings to 10p a minute wap because I only use it for football scores and dont fancy getting stung £7.50 for a few results.
    Cheers again
  4. nokiaman
    nokiaman
    No Probs mate glad to help.
    I know what you mean crazy amount of money to browse info.
