samsung dvi players
Discussion in 'Blu-ray & DVD Players & Recorders' started by pacemaker, Sep 2, 2003.
  1. pacemaker
    pacemaker
    Aug 31, 2003
    547
    +17
    as im in the process of buying a new projector with dvi input i find this very interesting
    http://www.samsung.com/Products/DVDPlayer/Hypervision/index.htm
    having recently seen the advantages of a htpc connected to simular high end pj i was resigned to the fact that id have to invest in a new pc and all the problems that go with it as i just couldnt go back to a standard dvd player on component inputs
    i must add that the pc was a non expensive model and yhe comparism was against a new tag mclaren dvd playay....the pc blew it out of the water
    could this be the answer weve all been waitin for?
  2. pacemaker
    pacemaker
    Aug 31, 2003
    547
    +17
    just found out samsung hd935 will be european version of hd931
    which itself has pretty good revies
    due out this month
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    what does it output via DVI?
  4. mseabroo
    mseabroo
    Aug 28, 2001
    376
    28
    Sussex
    +41
    Pictures :devil:
  5. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,163
    38
    Australia
    +18
    480p,576p,720p,1080i via DVI from the specs....I want one please...where have you been offered one.
    Ian Guinan
  6. philipb
    philipb
    Mar 6, 2002
    1,989
    63
    Swindon
    +132
    Pacemaker's gone very quiet on this one:confused:
    Need to know if the DVI is HDCP - probably - in which case it may not suit your display (eg the Pio 433 won't take a HDCP signal unless you replace the 5002 card with the aurora card).
  7. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Ian, you are keen as well, keep in touch!
  8. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,466
    Surrey. UK.
    +2,116
