C
Corf68
Hello,
I'm having problems connecting my new Samsung DVD recorder to my Samsung LE32R LCD TV, and am finding the instructions very confusing. There seems to be three ways to set it up and I'm attempting to use the HDMI cable route - nothing else is to be connected. I was advised that there would only be the three connections between the TV and DVD if doing this, i.e. HDMI cable, aerial cables and Scart but I'm now not so sure about whether the Scart connection should be used; instead, the manual appears to suggest that the colour coded jack plugs only need be used when connecting via HDMI.
I've got all the Freeview channels but the picture quality and sound isn't as good as it was prior to connecting the DVD recorder. I'd be very grateful for any clarification on what I'm doing wrong.
Also, is it correct that the DVD must be switched on in order to view all the digital channels? I only seem to be able to get analogue when the TV alone is switched on, whereas previously, all Freeview digital channels were available through the TV.
Many thanks.
Many thanks.
