Samsung DVD s-126
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by yehuda, Jul 6, 2005.
  1. yehuda
    yehuda
    I bought a Smasung DVD s-126 a while back and the box said it was multizone.
    It came with a little paper with a little code I had to do to make it multizone...It worked fine..Like press this and the enter code so and so, yatyta...
    I unplugged the DVD player for a while and now it does not work anymore...I lost the little paper with the instructions on how to do it.
    Can you please tell me??? Anybody???
    Thannx
  2. yehuda
    yehuda
    Turn it on wait for "no disc" t appear.
    Then click 'repeat"
    enter code 38767
    then enter 9 (for multizone)
    then press open.
    Thats it!!!
    I foundt!!!!
