Samsung DVD not reading discs
Discussion in 'Home Cinema Buying & Building' started by daddyp, Aug 24, 2005.
  1. daddyp
    daddyp
    I've had the samsung XXXX120 (sorry can't remember the full code) for about 18 months. It was only a cheap system bought from currys for £130. The sound quality is great but it's stopped reading and discs, I just get the No Disc Loaded message. I believe this is a common fault with this machine.
    I'm wondering how much does it cost to get it fixed. Is it the lens that has gone and can it be done without an engineer?
