Samsung DVD-M105
Discussion in 'Blu-ray & DVD Players & Recorders' started by samson, Jan 24, 2002.
  1. samson
    samson
    Having tried the handset region hack without sucsess can anyone help with this problem???????
  2. alextgreen
    alextgreen
    Apr 17, 2001
    549
    London
    +5
    A friend of mine just reported the same problem when I got her the crack. A lot of handset cracks involve opening the drawer first, so that *may* be worth a go.
  3. samson
    samson
    Thanx Alex but that still does not seem to work.
    The drawer closes after pressing first number is that supposed to happen?
  4. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    All I have is this cut&paste from my pre-xmas present research:
    Always perform a Cold Start before applying the hack below:
    Power on your player whilst pressing hold both the Play and Stop buttons on the front player
    After a short while you should be presented with a set of language options. Release the Play and Stop buttons on the player
    You will now need to select a language option between 1 and 6
    To convert this player to Multi-Region playback:
    Press the Repeat button on the Remote Control
    Using the Remote enter the code below, note that you must know what Region your player is currently set to in order to know which code is appropriate
    for Region 1 use 2, 9, 3, 3 and 4
    for Region 2 use 3, 8, 7, 6 and 7
    for Region 3 use 5, 6, 7, 3 and 2
    for Region 4 use 7, 6, 8, 8 and 4
    for Region 5 use 5, 3, 8, 1 and 4
    for Region 6 use 2, 4, 4, 6 and 2
    A code should be displayed on the screen indicating the current Region setting of your unit
    Press the 9 button on the Remote Control for Region free, or 1 for Region 1, 2 for Region 2 and so on
    Press the Open button on your player
    Press the Standby button on the Remote Control
    If the player sticks on FBI Warning screens:
    Press Forward Search x2 or faster, the disc should skip straight to the main feature
    If you have a player with newer firmware i.e. 5.02E try this:
    Press and hold both the Play and Stop buttons
    on the player itself
    set of language options. Release the play and the
    stop buttons on the player
    between 1 and 6
    Press the Repeat button on your Remote Control
    Now using your Remote Control enter the code below,
    appropriate, for Region 2 use 5, 7, 5, 3, 8 instead of 3, 8, 7, 6, 7
    Press the 9 button on your Remote for Region free, or press 1 button for Region 1, button 2 for Region 2 and so on
    Press the Standby button on your Remote Control
    Problems:
    This hack may not work for machines with the 5.02E firmware loaded. Try the Samsung V-5000 hack, it MAY work.
    I eventually forgot this handset crap and did the sensible thing, bought a player modified for my parents. Works a total treat!
