samsung dvd m105/xeu
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by bigguydoc, Mar 27, 2006.
  1. bigguydoc
    bigguydoc
    hello just joined so forgive me if asking wrong questions.i have backed up a music disc and cant play it on the above mention dvd player.any help would be appreiated.:lease:
  2. garymv
    garymv
    P243, DVD-511, DVD-611, DVD-709, DVD-711, DVD-809, DVD-811, DVD-909, DVD-MC20, DVD-M105, DVD-M108, DVD-M203, DVD-M204, DVD-M205, DVD-M405, DVD-HD937
    Multi-Region Code 1:
    Always perform a Cold Start before applying the hack
    Power On your player whilst pressing hold both the Play and Stop buttons on the front player
    After a short while you should be presented with a set of language options. Release the Play and Stop buttons on the player
    You will now need to select a language option between 1 and 6
    Multi-Region Code 2:
    Press the Repeat button on the Remote Control
    Using the Remote enter the code below, note that you must know what Region your player is currently set to in order to know which code is appropriate
    for Region 1 use 2, 9, 3, 3 and 4
    for Region 2 use 3, 8, 7, 6 and 7
    for Region 3 use 5, 6, 7, 3 and 2
    for Region 4 use 7, 6, 8, 8 and 4
    for Region 5 use 5, 3, 8, 1 and 4
    for Region 6 use 2, 4, 4, 6 and 2
    A code should be displayed on the screen indicating the current Region setting of your unit
    Press the 9 button on the Remote Control for Region free, or 1 for Region 1, 2 for Region 2 and so on
    Press the Open button on your player
    Press the Standby button on the Remote Control
    Firmware Version 5.02E:
    Power on your player
    Press and hold both the Play and Stop buttons on the player itself
    After a short while you should be presented with a set of language options. Release the play and the stop buttons on the player
    Press the Repeat button on your Remote Control
    Now using your Remote Control enter the code below, note that you must know what Region your player is currently set to in order to know which code is appropriate, for Region 2 use 5, 7, 5, 3, 8 instead of 3, 8, 7, 6, 7
    Press the 9 button on your Remote for Region free, or press 1 button for Region 1, button 2 for Region 2 and so on
    Press the Standby button on your Remote Control
    Further information has emerged for the very latest players. The only drawback with the below is that it isn't held when the player is switched off. You also need an Aiwa remote control, our forum visitor used the Aiwa RC-7AS08:
    Turn on the player
    Open the DVD tray
    Press Sleep on the Aiwa Remote, and you will see a cold start message on screen
    Press Clock 3 times very quickly, pressing and pressing, you will see an adjust message on front of DVD player
    Put any Region of DVD in and it will play
    It may also work with other Samsung DVD-Mxxx models, but may not work for machines with the 5.02E firmware loaded. Try the Samsung V-5000 hack, it MAY work.
    If the player sticks on FBI Warning screens:
    Press Forward Search x2 or faster, the disc should skip straight to the main feature
    Thanks to Arfan, Dave and Andrew for the additional information
    DVD-M103
    Multi-Region:
    Turn On your DVD Player with the remote control
    Press the Open/Close button on your remote control (tray will Open)
    Press the Open/Close button on your remote control (tray will Close)
    Press the Repeat button on remote
    Press 9 on remote for Region free, or 1 for Region 1, 2 for Region 2 and so on
    Press Open on player
    Press Standby on remote
    If the above code doesn't work then you may wish to try the codes above.
    hanks to Erick for the additional information
