Samsung DVD M105 handset hack (Reversable?)
R
robowen
I have a Samsung DVD M105 player.
I would like to use the handset hack to play R1 disks but i would first i would like to know if once done can it be reversed or will it be stuck on R1? I don't really want to use (9 - multi region) because RCE disks won't play on them.
Any advice?
cheers
Lux
AFAIK u can always go back to R2.
but to be sure that u get the right answer, post your question in the harware forum as more people will know about it.
HTH
Lex
Originally posted by Lux
but to be sure that u get the right answer, post your question in the hardware forum
Moving... :D
S
smallman28
I got the S224 for my parents which uses the same handset hack as the 105 and I set it to the region9 setting and it does RCE no problem.
