samsung dvd-M105 hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by T1969, Aug 21, 2001.
  1. T1969
    T1969
    Aug 21, 2001
    132
    South East
    +4
    Hi, does anyone have the correct hack for the samsung M105. The hack printed in What video & Tv does not work. I am new to Dvds and am wondering if im doing something wrong.
    Your ideas would be greatfully received
    Many thanks.
    Tim Davies
  2. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    If you have got the language display up, chosen 'english', then pressed 'repeat', 38767, followed by '9' for all regions - then I don't know where you're going wrong.
    This has worked on almost all samsung machines.
    You are pressing the normal 'repeat' button aren't you, not the A-B repeat?
  3. T1969
    T1969
    Aug 21, 2001
    132
    South East
    +4
    THANKS FOR THE REPLY. THE HACK YOU DISCRIBE IS COMPLETLY DIFFERENT FROM PUBLISHED IN THE MAGAZINE. I WILL GIVE IT A GO. CHEERS
  4. ferdipollo
    ferdipollo
    Please, could you explain exactly how I have to do the hack for samsung M105. I tried it several times and no region code appears onscreen after typing 38767. Maybe I'm doing it wrong.
  5. T1969
    T1969
    Aug 21, 2001
    132
    South East
    +4
    FROM A COLD START,PRESS & HOLD THE PLAY AND STOP BUTTONS, CHOOSE ENGLISH THEN PRESS REPEAT, PRESS 38767 TYPE IN THE REGION NUMBER YOU WANT, PRESS OPEN THEN STANDBY ON THE REMOTE AND YOU ARE READY TO PLAY YOUR NEW REGION. tHIS IS THE Way described in sept issue of what dvd.
    hope it helps
    Tim1969
