SAMSUNG DVD-HR720: Hack Please
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by blueprintz, Sep 20, 2005.
  1. blueprintz
    blueprintz
    Does anybody have a a hack for the SAMSUNG DVD-HR720 Model... I am really struggling here and need some desperate help :lease:
    I have looked on a myriad of websites with different DVD hacks... so please don't reply with any websites as the there is 99% I've been there with no success...
    It's currently set at Region 4 (Australia) I would like it to be Multi Region.
    Thank you very much. :)
  2. Goran65
    Goran65
    Feb 20, 2006
    3
    his will work for those in Australia with a DVD-R121, DVD-R100 & DVD HR720 Region 4 machines
    1. Ensure NO disc is in the machine.
    2. Using the remote, press '0' 4-5 times a second apart.
    3. Press REPEAT button.
    4. Press '76884' (this is the R4 region code). If done correctly a small '4' appears for a second in the top left of screen.
    5. Press '9' while the '4' is displaying onscreen and the number 4 changes to number 9.
    6. Open and close disc tray.
    If all appeared as mentioned above and you undertook the steps correctly, you should now have a region free player.
  3. garymv
    garymv
