We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Samsung DVD-HD950
Discussion in 'Blu-ray & DVD Players & Recorders' started by lofty29, Oct 19, 2005.
  1. lofty29
    lofty29
    Sep 29, 2005
    202
    +3
    Hi there,
    This HDMI dvd player is launched on the 31/10/05 I was just wondering if anyone has got any opinions on it. It costs £99.99 from play.com delivered, and it comes with an HDMI cable included, is it a bargain or should I stay clear.
    Lofty :thumbsup:
  2. kato670
    kato670
  3. unique
    unique
    Aug 14, 2005
    9,381
    +1,211
    play has it at £99.99 from 31/10 yet its been out a while, i got mine from richer sounds at £129.99 - you can easily make it multi region from the hack at www.dvdrhelp.com
    its a well built machine, a few niggles, but for something that plays most discs, sacd and dvd audio and divx, its not bad for the money, and comes with a dci-hmdi and hdmi-hdmi cable
    once you get over the niggles it's not a bad player. if you check my other posts you'll see some more comments about the problems and how to get round them
