Samsung DVD HD935 - DVI signal booster ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by chris l., Nov 1, 2003.
  1. chris l.
    chris l.
    Mar 31, 2002
    272
    +3
    DVI signal booster, do they exist and do they work ?
    Hoping to go the Samsung DVD-HD935 via DVI-D to Sanyo PLV-Z2 but have read 5m is max dvi cable length for good signal transfer.
    Have noted on Amercian based forums people have used electonic signal amplifiers etc.
    I need to run a dvi-d cable circa 14m.
    If this is not possible what is the maximum length a good component cable can run too, if i switch to a Denon DVD2200
    Thanks in advance.
    Chris L.:confused:
  2. uczmeg
    uczmeg
    May 18, 2003
    3,217
    71
    Nottingham
    +51
    Max recommended cable length for DVI is supposedly 7.5m.
    Many do better.
    I use a Samsung 935 with a 10m DVI cable and have no problems at all.
    Marc
