Samsung DVD-HD745 (945) playback problems?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Camillo, Jan 14, 2005.
  1. Camillo
    Camillo
    Jan 14, 2005
    22
    3
    Has anyone experienced problems with playing standard DVDs using the new Samsungs? My 745 has clear problems with read errors when I start it up - however, after a while, the problems seem to diminish significantly. I can watch an entire movie without problems, but the first few minutes usually lead to read errors or complete lock-ups.
    I have the player hooked up to my 32PF9986 using DVI, and currently I tend to use 576p. However, the errors persist also on 720p, and most probably regardless of resolution.
    I'm just wondering if this may be a pickup problem (heat-related), or if it is a general issue with the players.
  2. dbisping
    dbisping
    Dec 14, 2004
    42
    Nothing noted here on my 945 feeding the Tosh DLP at 720p
    Dave...
  3. thebigkung
    thebigkung
    No problems here. 945 -> pio 434HDE via HDMI 720p
  4. Maranaz
    Maranaz
    I use a HD745 linked to LG Plasma via DVI and have an excellent picture. I have experienced no read problems on either Region 1 or 2 Disks.
    Cheers,
    Maranaz
