K
krosoft
Hello,
I have got a Packard bell lcd 300sw screen with a dvi connector and a samsung hd 945 dvd player with an hdmi connector.
I try to use an hdmi-dvi cable to connect the two but it did not work.
I suppose it is due to the fact that the lcd is not hdcp compliant, i search a lot of forum or manufacturer document but no info on this matter.
Do you know if it is possible to disable hdcp for the samsung hd 945 ?
Thanks for your help.
