Samsung DVD-511 hack?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Stuart Wright, Dec 23, 2001.
  1. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,602
    7
    167
    Birmingham, UK
    +10,466
    Can anyone please supply the hack for this as I'm told the hack in our database doesn't work.
    Our hack is:
    Switch the player off completely and then back on. You will need to know what region your player is currently set to in order to complete the procedure. With your remote control:
    Press and hold down Play and Stop together until you see a language menu.
    The language as required by pressing the appropriate button 1 through 6.
    Press Repeat.
    You now have to enter a sequence of numbers depending on what region your player is currently set to. We have listed the numbers for each region 1-6 below:
    2, 9, 3, 3 and 4
    3, 8, 7, 6 and 7
    5, 6, 7, 3 and 2
    7, 6, 8, 8 and 4
    5, 3, 8, 1 and 4
    2, 4, 4, 6 and 2
    You should see a confirmation message.
    Now select the desired region, 1 for region 1, 2 for region 2 etc. or 9 for region free.
    Press Open, then Standby
  2. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    From what I can gather, Spectre, if that hack doesn't work, than you are simply out of luck.
    It seems some machines are running one type of firmware which allows this remote hack, others are using different firmware for which the remote hack will not work.
    As far as I know there is no other method of remote hack.
    If anyone knows differently - please post.
