Quantcast
Samsung D7000 Owners Thread *Part 4*
BOUMSONG
001021
And yes that is pretty much what I am saying. I can stream stuff through all shared with a wired connection, but I can't really do anything else.
SteveU30
BOUMSONG said:
001021
First things first, update the Firmware to the latest version which is 1025.1 from here then report back: http://www.samsung.com/uk/support/model/UE46D7000LUXXU-downloads
Make sure you make a note of any settings you have altered on the TV first as they may get reset during the update (usually don't but just to be safe).
BOUMSONG
I downloaded the .exe firmware file.
Copied it to a USB stick.
Went to Software Upgrade > By USB on my TV
TV then says 'NO file available to upgrade. Please check it and try again.'
BOUMSONG
Just wiped my usb drive and redid everything, also tried another USB port on the TV. Same outcome.
This could be yet another example of this TV being buggered.
SteveU30
It's a while since I did it but I'm pretty sure you don't copy the .exe to the stick, you run the .exe on the PC and it then copies the files to the stick in the correct format.
denziloshamen
That is correct. Download exe to your desktop, double click on exe file and save the file that occurs as the outcome onto your memory stick when prompted. Then try with your tv again and it will work just fine.
BOUMSONG
Ok thanks. I upgraded the software but the exact same thing happens when trying to do the wired connection wizard.
'IP auto setup failed. Try the following...'
Yet I can connect to my PC via all share
SteveU30
Might be worth doing a factory reset to see if that makes a difference.
BOUMSONG
Pretty sure I did that already.
I haven't done any configuring on my router in yonks because I've never needed to. Generally I just plug and play wired devices, or just add my WPA code for wifi.
Is there anything I should check?
SteveU30
Make sure that UPnP is switched on in the router settings first off.
ickle
Mine does a blink at 21.## hours every night does more than that but have noticed the one 9pm area everytime
It also switched off then straight back on once.
Anyone suggest a fix ?
Regards stuart.
nissan04
is there anyone out there,that can help me regarding the smart hub.ihave heard people say that you can change the background wallpaper, as there are only 2 given. i am at present on the dark background and want to change it two the water like effect one if this can be done at all.
daveb975
I didn't think that this could be changed, the dark background seems to be standard on the D series and the water effect one is on the later ES series.
I might be wrong, though, as I have never tried.
Rader123
Need urgent help please. Today, all of a sudden, the picture on my D7000 changed and the picture now looks much less clearer than before. Its much less brighter.
The best way to describe this would be as if almost all the programmes were filmed under very cloudy and grey skies, and the programmes also look like as if they were filmed in the 90s as opposed to now. Its not grainy but is not very clear, either.
I may need to reset the TV. How do I do this, unless there is another option. I have checked my external TV aerial which is standing in the roof as it should be and connected to the TV as it should be.
Rader123
The TV is still playing up. The screen goes darker after around 10-15 minutes in (sometimes even less time). Its like going from a bright sunny day to a dark cloudy day as far as the picture is concerned. I now wish I had bought it from John Lewis with a 5 year guarantee. £1750 TV and already playing up just over a year in. I really think Samsung shouldn't release their TV's until they test it thoroughly. There have been way too many complaints and returns on this TV.
Rader123
Looks like the problem was solved through a factory reset. I will wait a day or two to be sure though. Howoever, the reset has resulted in loss of the HD channels (BBC1 HD on 50, ITV HD on 51 and C4 HD on 52 and BBC HD on 54), though the picture on SD channels seem to be significantly better now.
Shamsung
Greetings AVforums, been a lurker for a while but had a few questions.
  • Does anyone have any tips on improving the performance and responsiveness of the UE 55 D7000 series? Samsung just told me to reset it all but I've done that many times. I can only take so much. I guess they're not really interested in extending the functionality now they've added 1-2-3-4 and 5 on demand. EPG and Smart Hub both slow.
  • Have any of you had good experience with alternative remotes? I've thought maybe Bluetooth would make life easier RE: my first question. Interested in either standard remote or one with a keyboard on the rear, might be nice for searching on demand services.
  • Has anyone managed to get audio out from the headphones and built in speakers simultaneously? Really frustrating as we use an external speaker and the optical out volume is very low.
  • Is there a "game" picture mode? I've read about it in the settings thread but can't find it here.
Urien Rheged
The 'Game' mode is under 'System'' then 'General'.
SteveU30
Wonder if anyone can help,
Do samsung still supply panels for the d7000? My tv has developed clouding and i have a extended warranty just wondering if they can get hold of a replacement panel UE46D7000
From what I can gather the D7000 uses the 46A2UF7E panel which was last used on the D series so hasn't been in production for over a year. Not sure what supply will be like but I imagine when they're gone, they're gone. It's quite likely that you'll end up with either a repair (new panel), refurb set or even a new one depending on panel availability.
beckford
Thanks for the reply,
Could I refuse a refurb?
SteveU30
The Sale of Goods act says no but the Ts & Cs of the extended warranty may be more generous, you'll have to dig them out and see what you are likely to expect in the event that your TV is condemned.
beckford
Dosent really mention anything about refurb etc just that if they can't repair it they will give me an equivalent or value of purchase price, will ring them on Monday and see what happens. A lot of people are saying that clouding is acceptable and may not even repair or replace!
Similar threads
Trending threads
Latest News
High End Munich 2020 Hi-Fi Show cancelled
  • By Andy Bassett
  • Published
Samsung leads global TV market for 14th straight year
  • By Andy Bassett
  • Published
Apple wireless home cinema audio hinted by patent?
  • By Andy Bassett
  • Published
Samsung and BT deliver UK’s first live 8K sports broadcast
  • By Andy Bassett
  • Published
Bowers & Wilkins confirms corporate changes
  • By Andy Bassett
  • Published
