Samsung CRT CW-29Z404N with horizontally displaced imaged / Lateral black bar
Waveshock
Hi everyone. I recently purchased a 29 inch Samsung CRT TV, model CW-29Z404N. I don't know about how much it has been used or how long it's been stored. Externally it looks great, like new. Sadly, when it's turned on, the image it's horizontally displaced to the right, leaving a black bar on the left of the screen. Also, it can be observed that the image slightly trembles, but it's still sharp. The colours are also correct. I should add that the image displacement and the tremble were greater the first time I turned the tv on, but decreased after being plugged in for a while. After accessing the service menu, I found out that all the options in the "deflection" submenu works correctly, except for the "h-shift" which does not respond, even introducing very high values one way or the other. Hope you can put me on the trail of what's causing this problem, and if it can be repaired. Thanks in advance.
